1996 Dodge Ram track bar
MARCOS17
  • 1996 DODGE RAM
Suspension problem
1996 Dodge Ram V8 Four Wheel Drive Manual 198 km miles
could I change the track bar on my 1996 ram or is it best I take to my mechanic for special tools?
Do you
have the same problem?
Saturday, March 6th, 2010 AT 4:41 PM
CARADIODOC
  • EXPERT
What's the symptom? Simple bolt on the passenger side of the front axle. Tapered stud on the driver's side frame can require a lot of banging on the frame bracket to shock it loose, or use a tapered "pickel fork" to force the stud out.
These commonly cause steering wander. I have a simple test procedure. Look for a replacement with a lifetime warranty because they fail so often.
Caradiodoc
Tuesday, March 9th, 2010 AT 3:50 PM
Recommended Guides
