1995 Dodge Ram no start
FIFTYFIFTY
  • 1995 DODGE RAM
  • V8
  • 4WD
  • 130,000 MILES
Intermittin no start one day runs great next day cranks but won't start no spark
Do you
have the same problem?
Sunday, November 15th, 2009 AT 12:53 AM
JDL
  • EXPERT
Welcome to the forum, any trouble codes? Check primary voltage to the coil and injector/s, dark green with orange tracer, engine cranking, do you have voltage? That voltage comes from the asd relay, not saying the relay is faulty, if the computer isn't grounding the relay, a common reason is the computer does see proper signal from cam or crank sensor. Maybe a trouble code would point you in the correct direction?
Sunday, November 15th, 2009 AT 12:13 PM
Recommended Guides
