1994 Dodge Ram loosing power
RICHIEB9995
  • 1994 DODGE RAM
  • V8
  • 4WD
  • 255,500 MILES
I have change the Cat. Converter the EGR the O2 sensor, and why is my truck still loosing power till the point that it stalls out. The gas pressure is at 40 lbs and holding. The vacuum is good. HELP!
Do you
have the same problem?
Wednesday, February 10th, 2010 AT 8:15 PM
  • EXPERT
Have you checked timing? If this is the original engine, have you checked engine compression?
Friday, February 12th, 2010 AT 6:28 PM
JHARSHFIELD
I have the same problem with my 94 ram 4x4
ive done everything that you have except for the cat. Conv. I was told by a mechanic that my flywheel ring gear is cracked or missing teeth. He said that there is a sensor in there that reads the teeth. Im gonna pull my started and inspection plate to see if I can see anything wrong.
Wednesday, February 24th, 2010 AT 7:50 PM
Recommended Guides
