1985 Dodge Ram Replacing Motor Mounts
DCOLBERT123
  • 1985 DODGE RAM
  • V8
  • 165,000 MILES
On 1985 Dodge B250 Ram Van, with 318 CID/5.0L V8.
Replacing right side motor mount. Rubber pad on old mount was so bad, old mount came out in 2 pieces. Can't get engine jacked up high enough to install new mount,
Please Advise.
Do you
have the same problem?
Friday, January 11th, 2008 AT 12:36 AM
MERLIN2021
  • EXPERT
Sometimes you need to remove parts on top to get the clearance, also you may need to remove the left mount. If only of a wee bit you can try grinding the stud just a bit.
Friday, January 11th, 2008 AT 3:22 AM
