Check your own Codes --
DONOVAN2007
  • DODGE NEON
Before you call your dealer or mechanic, check your own Codes --
1. Start with the ignition off. Within five seconds, switch the key on, off, on, off, on. (On is *not* start!)
2. The "check engine" light will flash. Count the flashes Each code is a two digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (loong pause) = 23
FLASH (pause) FLASH FLASH (loong pause) = 12
3. Code 55 is end of codes.
Do you
have the same problem?
Thursday, December 20th, 2007 AT 6:30 AM
NEON04GANDB
The code was P0700
Saturday, August 22nd, 2009 AT 11:37 PM
Recommended Guides
