I have the same problem. My 1995 will go down road for about 20 miles, then stall/die. It wont start again for about 30 minutes then will go 1-2miles and die again. If you wait several hours it will start and drive fine for another 15 miles. If you let overnight then goes it 20 miles then dies. Checked/changed cam shaft sensor, coil, crankshaft sensor, fuel injectors and pressure, there are no codes on computer.
Any ideas? Someone said maybe fuel pump heats up and then dies?
SPONSORED LINKS
Monday, August 6th, 2007 AT 10:58 AM
