Tail lights don't work
THEMRBCROWDER
  • 2002 DODGE NEON
  • 145,000 MILES
My dashboard lights went out and now my tail lights don't work. Which fuse(s) in my 2002 dodge neon controls the dashboard lights and tail lights?
Saturday, December 3rd, 2011 AT 2:31 AM
DRCRANKNWRENCH
  • 3,380 POSTS
It sounds like you have a fuse out or the headlight switch is not working right, Here is a guide to show you how to find when you loose power.
Here is wiring diagram so you can see how the system works and the fuse locations
Check out the diagrams (Below)
Cheers
Saturday, December 3rd, 2011 AT 2:40 AM
THEMRBCROWDER
Yep it was the headlight switch I used the guide you gave me and saw it lost power through the switch. Thanks for your help this site rocks water back.
Monday, December 5th, 2011 AT 2:20 AM
VLADIMIR07
  • 1998 DODGE NEON
  • 4 CYL
  • FWD
  • 114,000 MILES
Electrical problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic 114000 miles
Okay I have a dodge neon 1998. Few days ago my tail light when out they don't work any more, they wont work when I break they wont work when I use my turning signals they only flash in the front of my car and inside my car in the dash board when I used my signal they flash really fast and when I turn on my hazards they flash normal but it still wont flash any light from the outside of the vehicle. I already putt in new light bulbs and new fuses and I don't think its the flasher cuz my light still flash in the front of my car so I don't know what it could be so if you could help me out plz do!
Thank you
Sunday, April 1st, 2018 AT 3:57 PM (Merged)
JDL
  • 16,098 POSTS
Your tail lamp gets voltage from the headlamp switch. At the rear black wire with yellow tracer, see if there is any voltage on that wire, with the headlamp switch on. Dark green with red tracer is for stop/turn. Black wire is ground.
At the lower rear, your brake lites are wired through the turn switch. The stop and turn use the same bulb filament, just not at the same time, for lower. The high-mount brake lite is wired a little different.
I'd check the voltage and ground circuit at the rear, to start.
https://www.2carpros.com/forum/automotive_pictures/170934_neon_rear_lites_1.jpg
SWEETPOTATO
  • 1997 DODGE NEON
  • 4 CYL
  • FWD
  • 316,000 MILES
My dash lights, meters and tail lights stopped working at the same time a couple of weeks ago and I checked the fuses and none of them were out. I was just wondering if the fact that they both stopped at the same time is just a coincidence or if it's a common problem and I was wondering what a solution would be. The turn lights, headlights, highbeams, radio and air work but the spedometer, odometer, gas levels, engine temperature and all dash lights do not.
BMRFIXIT
  • 19,053 POSTS
Remove the fuse out and check
turn lights on and then check the fuses
CMSCHAD
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 80,000 MILES
The running lights in my car will not work, also the interior lights on my dash, and also the stereo work fine along with my interior head lamp. Also my rear running lights will not come on, I tried to change the fuse and it blows as soon as you flip on the lights. I have been trying to find a fail safe but cant figure this one out! HELP! I am tired of only driving in the day time. Lol
CH112063
  • 1,320 POSTS
Try taking the switch out and see if it still blows. I know what you mean about driving during the day. I would try that. See
