2005 Dodge Neon Check Engine Light
GGSTOTT
  • 2005 DODGE NEON
  • 4 CYL
  • MANUAL
  • 45,000 MILES
Ambient air senson circuit low and high (P0071 and P0072 respectively).
Also has P0300 indicating engine missfire.
I've ordered the ambient air sensor that mounts to the air cleaner (intake). Its only $12 so I thought I would start there.
Dealer suggested I next try the O2 upstream sensor next.
Any other suggestions? Any change its bad spark plugs or wires?
Gene
Do you
have the same problem?
Friday, May 16th, 2008 AT 11:59 AM
BMRFIXIT
  • EXPERT
I would start with a tune up 1st
Friday, May 16th, 2008 AT 8:14 PM
Recommended Guides
