2004 Dodge Neon
GARY CHOATE
  • 2004 DODGE NEON
  • 4 CYL
  • FWD
  • 100,000 MILES
I have a 2004 dodge neon sxt That dont want to idle when I stop at a red light but otherwise runs fine
Do you
have the same problem?
Thursday, November 4th, 2010 AT 10:01 AM
WRENCHTECH
  • EXPERT
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Thursday, November 4th, 2010 AT 10:32 AM
Recommended Guides
