2003 Dodge Neon BREAK LIGHTS?
03SHORTY
  • 2003 DODGE NEON
Electrical problem
2003 Dodge Neon Automatic 85811 miles
Why did my break lights all of a sudden stop working? And how can I go about getting them fixed?
Do you
have the same problem?
Wednesday, January 6th, 2010 AT 8:52 AM
JDL
  • EXPERT
Welcome to the forum. Does the high-mount brake lite work? If not check the brake switch and wiring circuit. The brake switch should be located on the brake pedal support. Voltage to the brake switch, pink wire with dark blue tracer. When the brake switch is activated, the white wire with tan tracer carries voltage to the brake lites. You can use a testlite on those wiring circuits, see if they are hot?
Wednesday, January 6th, 2010 AT 9:47 AM
Recommended Guides
