1996 Dodge Neon CAR OVER HEATING
MARIA DIAZ
  • 1996 DODGE NEON
  • 4 CYL
  • FWD
  • 150,035 MILES
HI, IV HAVE A 1996 DODGE NEON IT WAS OVERHEATING SO WE CHANGED THE THERMASTAT, AND CLEANED OUT THE RADIATOR, IT RUNS GOOD BUT WHEN I TURN ON THE A/C THE METER STARTS MOVING UP. AND IT OVERHEATS.
Do you
have the same problem?
Thursday, August 6th, 2009 AT 12:00 PM
  • EXPERT
Hi there,
Thank you for the donation.
Check that the cooling fans are turning on as is the A/c condenser fan with the A/C, you say you cleaned the radiator, you may still have a number of blocked cores, this radiator should be flow tested by a radiator shop to ensure that it is totally clear internally and also get the pressure cap checked and ensure that the system is pressure tested as well.
Mark (mhpautos)
Thursday, August 6th, 2009 AT 5:19 PM
Recommended Guides
