HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine Cooling
Water Pump
Location
SPONSORED LINKS
Water Pump location
MITCHRF12
MEMBER
1997 DODGE NEON
Engine Cooling problem 4 cyl Two Wheel Drive Manual
Where is the Water pump located on a Neon and does the same belt run to the power steering pump?
Thursday, February 18th, 2010 AT 6:56 PM
KEN L
MASTER CERTIFIED MECHANIC
It is in the front of the engine under the timing belt cover, here is a diagram of the timing belt and water pump.
This guide will help you get started
https://www.2carpros.com/articles/water-pump-replacement
and
https://www.2carpros.com/diagrams/dodge/neon/1996
Cheers, Ken
Image (Click to make bigger)
SPONSORED LINKS
Tuesday, May 16th, 2017 AT 5:28 PM
COACHT
MEMBER
1 POST
1995 DODGE NEON
1995 Dodge Neon 4 cyl Front Wheel Drive Manual
I have removed the radiator to give myself more clearance to work but I still can not locate the water pump to change it out please help me.
Thank you
Tim
Tuesday, May 16th, 2017 AT 5:28 PM (Merged)
DOCFIXIT
MECHANIC
It is behind the front cover front of engine and pass side fender well
Please
login
or
register
to post a reply.
Related Water Pump Location Content
1997 Dodge Neon Water Pump
I Have Been Told I Need A New Water Pump Since I Have To Keep Filling Up The Coolant. What Is A Fair Price For The Replacement?
Asked by
badler1867
1 ANSWER
1997
DODGE NEON
1999 Dodge Neon Water Pump Leak?
Earlier Today I Was Driving And My Car Shut Off At A Stop Sign. I Got It To Start Again And It Shut Off At The Next Stop Sign, So After A...
Asked by
bwinders
1 ANSWER
1999
DODGE NEON
2003 Dodge Neon At The End Of My Rope
My Car Started To Over Heat Last Fall. I Took It To The Dealership. They Replaced The Radiator And Thermostat. It Was Ok For A While But It...
Asked by
mikes4736
1 ANSWER
2003
DODGE NEON
Radeator Water Is Not Runnig Its Bilding Up...
I Changed Water Pump Thermostat New Radiator Senser To Radiator. And The Car Is Still Making Pressure. But The Water Is Not...
Asked by
laurianorivera
1 ANSWER
2002
DODGE NEON
Is My Dodge Nein Worth Repairing Or Should I Give Up...
Its A 2000 Neon With 200000 Miles On It And Its Running Hot. The Antifreeze Is Boiling Out But The Fan Is Comng On. I've Had Different...
Asked by
Sadenicole
2000
DODGE NEON
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Heater Hose Replacement
Water Pump Replacement
Online car repair manuals
