1995 Dodge Neon
JOSEPHHART
  • 1995 DODGE NEON
Transmission problem
1995 Dodge Neon 4 cyl Automatic 100000 miles
Dodge Neon 2.0L 4cl
the moter starts up and runs the transmission is alwais in drive even in park as soon as I turn the key it trys to take off but im holding the brake and its an automatic do I need a transmission
Do you
have the same problem?
Monday, June 8th, 2009 AT 5:38 PM
BMRFIXIT
  • EXPERT
It should not start if its not in park and or neutral
check link cable also turn key on E brakes on
place shifter in reverse do u have reverse light on
dose it start with the shifter in R OR D
can you push and move the car when in P
let me know
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, June 9th, 2009 AT 5:00 PM
Recommended Guides
