Engine misses
DODGETHIS1987
  • DODGE MAGNUM
I have a 2001 Dodge Ram 1500 4X4 with the 5.9 liter magnum. The engine misses every once in a while. I believe it did it even when it was new. The miss dosent have a fixed spot it just does it randomly. Sometimes itll do it 3 or 4 times a day, then sometimes it wont do it for about a week. Then when it would do it, it might be at idle or I might be doing 75 down th highway. I can remember sitting in my driveway in the morning waiting for it to warm up and it would do it and the tachometer would drop about 200 rpm then would rise back up. It use to be really bad not to long ago. But I replaced the spark plugs, wires, distributor cap, and the rotor but it still does it. Just not as often or as violent as it use to be. Any ideas?
Do you
have the same problem?
Wednesday, March 8th, 2006 AT 2:28 PM
  • EXPERT
Has the check engine light ever come on?
Tuesday, March 10th, 2009 AT 3:26 PM
Recommended Guides
