Intrepid stalls
2PERCENT
  • DODGE INTREPID
OK I have a 1996 dodge intrepid with a 3.5 engine with about 65000 mi. On the motor 180000 on the car. The car ran great on the new motor until 3 weeks ago the crank positioning sensor went I repleaced that and the fuel filterto get it to start along with the idle control sensor a week later. It ran great one time. Now it starts fine but 5 minutes later itll stall. And u have to keep giving it gas until it reaches running temperature. Itll keep unstable idle until it reaches that point then it seems to run fine and no idiot ligths light up until it dies so there is no warning. And I took it for a drive even while drivin itll stall while givin it gas my fuel pump checked out ok and I think it could be an igniton problem. But once it reaches temperautre itll start and run fine just on cold engine starts it seems to be having the problem. Any suggestions? Thank you and a side note this will be the last dodge I own.
Do you
have the same problem?
Sunday, March 4th, 2007 AT 2:31 PM
Check the fuel pressure and comeback.
Sunday, March 4th, 2007 AT 9:07 PM
Recommended Guides
