2004 Dodge Intrepid
SIDEKIK09
  • 2004 DODGE INTREPID
2004 Dodge Intrepid 6 cyl
I own a 2004 Dodge Intrepid, and recently it started to overheat when parked or driving, it gets worse when I turned on the AC, the hotter it gets the AC gets hotter also. When I turn off the AC the engine will cool back to normal when driving on freeway or when parked.
Also notice it has to fans but only one of them will turn on and the other wont work, checked it by turning on the AC of and on still nothing. Are both fans suppose to be on at the same time?
I checked the fuses for the AC fan and radiator but both are still intact.
Do you
have the same problem?
Wednesday, September 1st, 2010 AT 5:35 PM
WRENCHTECH
Yes, the fans are supposed to run simultaneously and they are also 2 speed so you need a new fan assembly at the very least. See if you have 2 speeds at that point.
Wednesday, September 1st, 2010 AT 5:53 PM
