2001 Dodge Intrepid
BUDDY01TN
  • 2001 DODGE INTREPID
  • 6 CYL
  • FWD
  • 102,000 MILES
My 01 dodge intrepid 3.2liter acts like it has a dead battery. I have had the battery testd 3 times and evry time it has testd good with a full charge. When it put the battery back on the car it will crank right up. But the problem may return immediatly or may take a few weeks for the symptoms to come back. But I can unhook the battery for a few min and it will be fine. I can jump the car off and it will crank but the min I turn the ignition off the car acts like the battery is completly dead. I have had electrical test run and evry time has come back negative. Any help will b greatly appreciated.
Do you
have the same problem?
Wednesday, May 5th, 2010 AT 3:24 AM
BMRFIXIT
  • EXPERT
Sounds as a bad battery terminal or ground wire
Wednesday, May 5th, 2010 AT 5:35 AM
Recommended Guides
