2000 Dodge Intrepid automatic window
JOHNNY2DOPE69
  • 2000 DODGE INTREPID
  • 6 CYL
  • 150,000 MILES
I have a 2000 Dodge Intrepid ES. My automatic windows don't work unless my drivers door is open. What could be the cause of this? And how can I fix it?
Do you
have the same problem?
Monday, April 5th, 2010 AT 10:19 AM
INTERNETMECHANIC
Maybe the wiring harness is flexing, when you open and shut the door. There is probably a protective rubber boot, that covers the wiring harness, going into the door, hinge side. Sometimes you can pull the rubber boot back a little, to test wires. Tan wire is voltage, check with key on. Black wire is ground. You might tug a little on those two wires, one might be broken? They flex everytime you open and close the door.
Monday, April 5th, 2010 AT 1:29 PM
Recommended Guides
