1996 Dodge Intrepid FUEL PUMP
COREY HARPER1
  • 1996 DODGE INTREPID
Electrical problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
DOES FUEL PUMP HAVE RESET
Do you
have the same problem?
Tuesday, June 9th, 2009 AT 3:24 PM
JDL
  • EXPERT
Hello, no cut off switch. You might do some testing at the fuel pump relay in the power distribution center, under the hood. With the engine cranking, two of those terminals should be hot. You can unplug the relay, use a testlite. Maybe the computer isn't grounding the relay for some reason, that doesn't mean the computer is faulty. Can you check for codes?
Tuesday, June 9th, 2009 AT 3:52 PM
Recommended Guides
