1995 Dodge Intrepid Dodge Intrepid - Transmission Issues
TNTKIRKMAN
  • 1995 DODGE INTREPID
Transmission problem
1995 Dodge Intrepid V12 Front Wheel Drive Automatic
95 Dodge Intrepid - speedo doesn't work, and will not shift out of second gear.
Replaced the input sensor on the transmission and the speed control sensor in the dash. Neither helped.
Transmission will reset when car is turned off and restarted, but will return to limp home mode in less than one minute.
Any suggestions?
Thanks,
Tina
Do you
have the same problem?
Tuesday, June 2nd, 2009 AT 11:44 AM
DOCFIXIT
  • EXPERT
Need to have trans and engine scaned for codes
Tuesday, June 2nd, 2009 AT 12:02 PM
Recommended Guides
