1994 Intrepid, Belts
JETDR5
  • 1994 DODGE INTREPID
I lost my belts last night on the highway. I found the main drive belt wrapped around the crankshaft pulley shaft. I cut it off prior to installing the new belts and once the belts were replaced, it runs great. When I reached the house, I popped the hood and oil was all over the place. I believe there is a seal behind the crank pulley that I may have damaged with all the serpentine belt wrapped so tightly on the shaft. My question is can I just change that seal by removing the core support, radiator and pulley or do I need to go through the oil pan to replace the seal. Is it more than a seal? Is it bearings too?
Help. 1994 Intrepid, A/C, PWR Steering, 3.3 L and I have 142,000 miles on it. Great car just a misfortune with blowing the belts at 70MPH.
Zach
Do you
have the same problem?
Friday, July 6th, 2007 AT 2:19 PM
DGAKING
I have the same problem with the same car at 135,000 miles. I am also having a transmission problem that may be related. I'm up to 3200 RPMs at only 40mph. Are your RPMs higher than they should be? If the car is not shifting, I think the RPMs get too high and that may have broke my belt. Many ppl on this forum are having this transmission problem with the intrepids.
Saturday, December 22nd, 2007 AT 2:11 PM
