Shuts off while driving
ANONYMOUS
  • 1994 DODGE INTREPID
  • 300,000 MILES
Car quits running while driving down the road. Sometimes it will start back up but sometimes it wont.
Monday, January 14th, 2013 AT 9:36 PM
CADIEMAN
  • 3,544 POSTS
Take it to the parts store. Have The battery load tested. Also have the alternator output tested. This will test the whole charging system. This problem sounds like a bad alternator.
Monday, January 14th, 2013 AT 9:56 PM
This issue is most likely a crank sensor issue. Take a look at the guide below that gives a little more detail on it.
I attached the process on how to replace this and the info about the sensor itself. Basically the PCM thinks the engine was shut off and the engine just stalls. It doesn't start back up until the sensor is cooled down and makes contact again. This is typical in a hall effect sensor which is what your crank sensor is.
Please let us know what questions you have and we can go from there. Thanks
Monday, April 27th, 2020 AT 6:55 PM
GSD_GUY
  • 6 POSTS
Engine Mechanical problem
1994 Dodge Intrepid Front Wheel Drive Automatic
i have a 1994 DODGE INTREPID ES
SEDAN 4 DR
3.5L V6 SFI SOHC 24V
FRONT WHEEL DRIVE
My problem is when I start the car, and leave it sit it will idle fine and as soon as I turn my when to the far left and or far right, sometimes not even the far's my curse light comes on and my car stalls. This sort of stall is not a sputter stall it is short and to the point! Straight off. I'm thinking it might be an electrical issue ir even the fuel pump. Before I go in to a project I wanted to ask around. And where better to go? I have herd some real good things about this site so im going to start here! Thanks for the help!
Rob
Tuesday, April 28th, 2020 AT 12:36 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Is your check engine light on? If yes turn the key from off to on three times, on the fourth one leave it in the on position, count the flasshes.22 would flash as 2 blinks, then a short puase, then 2 more blinks. If several codes are stored, the pause is longer between codes, code 55 will be the last code. Do this and post all codes found.
Any loud squealing?
GSD_GUY
  • 6 POSTS
Nope, The light WAS on but I literally just changed the oil so it is now out. All fuses are good and checked and like I said before, the only lights that come on is the green cruse light fallowed by the abrupt stall. No coughing or squealing.
MERLIN2021
  • 17,250 POSTS
You may need to crawl under it, look at the steering rack and see if any wires are in the way(rubbing). This sounds like some kind of contact short. Speedo working OK? Also give this test a try and if any codes flash write them down and post please. 55 is normal and will be the last code displayed.
MERLIN2021
  • 17,250 POSTS
55 is normal and indicates the last code, 12 is battery disconnected in last 50 starts, look under the dash, pay attention near the steering column, it looks like and sounds like a wire rubbing on the column, or the ignition switch may have a problem, loose connection possibly. I am not talking about the key, but the plastic piece the harness plugs into.
GSD_GUY
  • 6 POSTS
I Will add that I recently added a bottle of lucas oil injector cleaner to the fuel. Like I said in the video, when I turned to the left it used to stall out, now it is only when I turn to the right. I checked over the wiring on the inside of the car, I have to crawl up under and see if there are any exposed wires. Im only looking for moving parts that would cause the short right?
MERLIN2021
  • 17,250 POSTS
OK, also get under the dash and check below. Instead of turning the wheel, wiggle some wires, when you tug the right one it should stall, then trace that wire and check it, and it's connector. Pull connector apart and inspect for bent pins or pushed out pins.
GSD_GUY
  • 6 POSTS
Ok, I will do that later today and post an update, I hope it works! Thank you for the help!
MERLIN2021
  • 17,250 POSTS
Will be here!
GSD_GUY
  • 6 POSTS
I moved and tugged on all the wires under the dash and under the car- hood. Nothing stalls out. I will add that when I turn I hear the power stearing stress out then it stalls. But again no wires.
MERLIN2021
  • 17,250 POSTS
First, when turning the wheel, you should NOT hold it against the stop in either direction, this stresses the pump and all seals, so release it a bit at the far stops. Next make sure nothing is being rubbed under the car while turning the wheel. If you release the wheel at the end stops, will it stall or not?
GSD_GUY
  • 6 POSTS
When I turn it almost grabs the wheel and then stalls, but my neighbor came over and mentioned something about a cable going to my strut that might have something to do with the problem. He put air in the tires (44psi) and drove it up and down the street a few times, after I told him there were no brakes he reversed over a curb going about 25 mph and destroyed my tire drivers back to be exact, he fixed the bumper(snapped in just that easy) then filled up the antifreze and it is not as bad now. It takes a lot to make it stall now, what ever it is the issue is beginning to be resolved.
MERLIN2021
  • 17,250 POSTS
OK, so it sounds like a wire was being rubbed by the strut? And now you have lost your brakes? 35 psi should be the Max on the tires.
LORAINE44
  • 6 CYL
  • FWD
  • 11,000 MILES
Our intrepid has been stalling while driving. 3 times ( in the rain and again in snow) this month, towed each time. The crankshaft and camshaft sensors have been replaced. The car stalled out again during our first snow storm last week. The machanics cant seem to find anything wrong.
Unreliable and unpredictable!
Any ideas?
Thank you, Lori
  • 108,179 POSTS
Hi:
When it dies, is it all at once or does it start running poorly then die?
LORAINE44
Our Intrepid stalls all at once, no for warning. The last time it stalled, we did get the engine to start about 10 minutes later, long enough to get it to the mechanic. The car starts the next day as if nothing was wrong.
Thank you, Lori
LORAINE44
Our intrepid stalled out last night, again, thanks to the mid west rain storm. We could not get it to start back up this time. We are on our way to try and start it this morning, though it is still raining.
I have not gotten any responses for a while, I guess this car problem has every one baffled.
Thanks
LORAINE44
