Power door locks
YOUNGSTUD50
  • 2000 DODGE DURANGO
  • V8
  • 4WD
  • 135,000 MILES
I recently had the heater core replaced in my durango. Now my power doors locks will unlock the doors but will not lock the doors. It seems like everyone once in a while it will work and other times not. Could this be a grounding problem or something else going on?
Tuesday, May 25th, 2010 AT 2:49 PM
  • 108,179 POSTS
Are all of the doors affected? Does the switch inside the vehicle work? Have you tried replacing the battery in the FOB? He may have inadvertently done something to the wiring to cause it.
The power lock wiring diagram is attached below
Monday, June 7th, 2010 AT 1:40 PM
JRLOPEZ1996
  • 2006 DODGE DURANGO
  • V8
  • 19,000 MILES
I have a problem w a power lock dont work any door
Friday, February 15th, 2019 AT 6:49 PM (Merged)
  • 108,179 POSTS
Have you checked for power to the main switch on the driver's door?
2CP-ARCHIVES
  • 4,542 POSTS
  • 1998 DODGE DURANGO
  • 180,000 MILES
Were do I find the door lock relay
Driver Unlock Relay On relay & fuse block
