Vibration
BD-5PILOT
  • 2000 DODGE DURANGO
  • V8
  • 4WD
  • 200,000 MILES
The front end shakes ( vibrates ) between the speeds of 20 mph to 60 mph. Seems like it only does it when you give it the gas. It stops when you let off the gas. Why?
Monday, May 30th, 2011 AT 12:04 PM
  • 108,164 POSTS
This sounds like a classic engine misfire causing the vibrations have you tuned the engine up lately if not here is a guide to help walk you through the steps.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Monday, August 29th, 2011 AT 5:01 AM
TURBOJAY
Thank you for this post I had this problem but after I tuned the engine up is went away I love this site!
Thursday, March 7th, 2019 AT 12:03 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 130,000 MILES
My car vibrates when I am slowing down. It does it even when not applying the brakes when slowing down. What can it be?
Thursday, March 7th, 2019 AT 12:04 PM (Merged)
CARADIODOC
  • 33,737 POSTS
The first suspects would be the universal joints on the rear drive shaft, and the transmission mount.
STANZ
  • 1999 DODGE DURANGO
  • V8
  • 4WD
  • 100,000 MILES
Im getting noise and vibration from front end, I took it in to be fixed and had the ball joints and 1 axle fixed but it didnt solve the problem, I dont believe the process of elimination is very economical. The noise increases as I accelerate.
  • 31,938 POSTS
Hi there,
Are you feeling the vibration through the steering or just the body?
Mark (mhpautos)
STANZ
No vobration in steering, just floor and body
  • 31,938 POSTS
Hi there,
If just in the floor & body I would be looking at rear tyres, rear end, rear drive shaft, if it was in the front you will get vibration felt in the steering, look at the rear end next.
Mark (mhpautos)
TESTOVERMO
  • V8
  • 4WD
  • 158,500 MILES
Excessive vibration coming from rear of vehicle. Only does it when it has been drove for 15 or 20 minutes and it dont do it all the time, but is doing it more frequently. Jacked rear of vehicle up and found in and out play in the wheels on both side of the rear of vehicle. What could this be? Also center of both rear wheels where hot to touch and smell of something getting hot.
STANZ
There seems to be a slight sound variation when I make a turn and the previous mechanic said I have a little play in both front wheels when the car was in the air he could shake them slightly
  • 108,164 POSTS
Is the differential full of gear lube?
  • 31,938 POSTS
HI there,
The front wheel bearings need checking.
Mark (mhpautos)
TESTOVERMO
It was a colapsed rubber brake line. Thanks for replying
  • 108,164 POSTS
I'm glad you got it fixed. Let us know if you have questions in the future.
DARKSKY
  • V8
  • 4WD
  • 160,000 MILES
What would cause a vibration in my 99 durango? I have replace the brakes, rotors, brake line, passenger wheel hub, and the upper and lower ball joints were replaced less than 3k ago. I had the tires rotated and nothing is loose or leaking in the rear.
  • 31,938 POSTS
Is this a steering vibration or a body vibration? Do you feel any increase in the vibration with the brakes on? (While driving)
mark (mhpautos)
CSMITH161
  • 2001 DODGE DURANGO
  • 112,000 MILES
My 2001 durango has a vibration noise on the front drivers side. When I turn to the right it goes away, (just the right, turning left still makes the noise). I was thinkin it might be CV joint but it doesnt have alot of play in it. I just had tranny overhauuled 10,000 miles ago(about yr ago). I am starting to get stumped. Ive recently replaced the brakes so thats not it. Im running outta ideas, anyone have a clue? Driveshaft, power steering?
FIXITMR
  • 9,990 POSTS
What about wheel bearing? They are noted for remitting when you turn.
