Power windows do not work
BRITT SAPP
  • 1999 DODGE DURANGO
  • 140,000 MILES
5.9 liter engine. Power windows do not work, power door locks only work on passenger side door. Fuses checked okay. Could it be the driver side electrical controls?
If so what parts would I look for?
Sunday, May 13th, 2012 AT 6:17 PM
HMAC300
  • 48,601 POSTS
There is a central timer module that sounds like it has gone out. Here is a wiring diagram so you can see how the system works.
Central Timer Module Behind right side of dash.
Cheers
Sunday, May 13th, 2012 AT 6:51 PM
GREG COLES
Yep I had this problem the shop charged me $240.00 to fix and reprogram it. FYI
Wednesday, July 25th, 2018 AT 1:07 AM
STEVE W.
  • 12,963 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site.
Sunday, July 29th, 2018 AT 7:42 AM
DICK WEGNER
  • V8
  • 4WD
  • 80,000 MILES
Both the passenger and right rear door windows do not work. They are in the up position. I have yet to work on the problem so if you could direct me to what I should check first and anything that could remedy the problem. Thanks for your help!
Friday, August 3rd, 2018 AT 7:28 PM (Merged)
DAVE H
  • 13,383 POSTS
Hello.
Both drivers and passenger side windows are on the same fuse so we can rule that out. There seems to be nothing connecting these two windows that could be a common fault to the two. Does the drivers rear window work correctly? The only thing all the windows have in common is the drivers door switch which has full control of all four. So I would be checking this first. Hope this helps. Let me know.
https://www.2carpros.com/forum/automotive_pictures/266999_dur_1.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_dur2_1.jpg
YOOPONE
  • 1998 DODGE DURANGO
V8 four wheel drive automatic 117, 00 miles.
One window was frozen and after a passenger applying a little too much force all windows stopped operating. I replaced the 25 amp CB in the fuse panel and all four windows still do not operate.
At the master control power window/lock switch check for power at the tan wire if power is present-check the ground circuit the black wire if okay replace the master control switch
Here is a guide to help you confirm the problem and get the switch changed out:
https://www.2carpros.com/articles/electric-window-repair
Cheers
YOOPONE
So you are referring to the switch that would lock all four windows at the drivers door control panel?
Yes Sir.
YOOPONE
No ground to the switches on the door. Took panel apart and replaced the switch worked great. Thank you so much this site rocks.
OZZSMOSIS33
  • 2000 DODGE DURANGO
V8 automatic 135,000 miles.
My windows will not work nor will my door locks on any of the doors. I cannot find a fuse for the windows. Is there one and could this be the problem? Thanks
OBXAUTOMEDIC
  • 3,711 POSTS
Look in the under hood fuse box for relays for the windows and door locks.
To test if bad once you locate the relays look at the others and match up the numbers then just pull the match and place it in the slot and see if works if does replace relay or relays
