Problem with it overheating
99DOORANGO
  • 1999 DODGE DURANGO
Engine Cooling problem
V8 Four Wheel Drive Automatic 225000 miles. I have a problem with it overheating. I know its not the thermostat, because I took it out. I also know its not the water pump, because its not leaking. It doesn't have a fan shroud on it. What could it be? The fan clutch?
Do you
have the same problem?
Monday, June 29th, 2009 AT 11:49 PM
  • EXPERT
First, if the t-stat is out, it may be allowing coolant to flow too fast and not giving it a chance to cool in the radiator, so I recommend getting one. Next, does the vehicle overheat in all conditions, for example, in town driving, highway? Also, there should be a fan shroud. THe fan needs it to draw air from out the front of the vehicle. Without it there, the air comes from everywhere.
Friday, July 17th, 2009 AT 4:42 PM
Recommended Guides
