Some injectors not getting a Pulse
SPEEDWAY MACHINE
  • DODGE DAKOTA
1993 Dodge Dakota, AT, 2WD, 170,000 miles, 5.2 liter.
I have an intermitent problem. At times one to two injectors do not get a pulse from the ECU. I have traced it back to the ECU and the ECU is not delivering the pulse. Is the ECU bad or could something else be causing the ECU to not deliver a pulse. The truck will always keep running it just runs a couple of cylinders short.
Do you
have the same problem?
Friday, June 1st, 2007 AT 2:08 PM
E40WATER12
Its quite posible you got a bad ECU.
Saturday, June 2nd, 2007 AT 7:49 PM
Recommended Guides
