2004 Dodge Dakota no turn signals or hazard warning lights-
HARRY MAC
  • 2004 DODGE DAKOTA
  • V8
  • 4WD
  • 55,260 MILES
On three different occassions I have had my turn signals and hazard warning lights fail. Each time I had to replace the 20 amp fuse.
On two other occassions I have had "check gage readings" light up on the dash. When I pull to the side of the road and shut down the engiine for a while then restart it goes away.
How can I pinpoint the computer problem?
Do you
have the same problem?
Monday, October 26th, 2009 AT 9:37 PM
  • EXPERT
If the check engine light has come on, there should be a trouble code stored in the computer. Take the truck to a nationally recognized parts store and have them scan the computer for codes. Most will do it for free and it should help identify where the problem is coming from. But to be honest, I question if the check engine light and the signals are related. Have you checked the flasher?
Friday, November 6th, 2009 AT 11:17 AM
Recommended Guides
