2001 Dodge Dakota Engine not running hot enough
DFOSTER55
  • 2001 DODGE DAKOTA
Engine Cooling problem
2001 Dodge Dakota V8 Four Wheel Drive Automatic
Truck was over heating. Took thermostat out. Went for emissions. Truck engine not running hot enough. Reinstalled new thermostat. How often does the computer check the code. Engine light still on. Will it go off on its own or will I have to take it to someone to get the check engine light off.
Thanks
Do you
have the same problem?
Tuesday, August 24th, 2010 AT 7:22 PM
  • EXPERT
Have it turned off with a scanner.
Wednesday, September 1st, 2010 AT 1:27 PM
Recommended Guides
