2000 Dodge Dakota
KAMARONDOWNS
  • 2000 DODGE DAKOTA
  • V8
  • 150,000 MILES
I had engine codes P0320 and P0700 come up. The truck would stall and when I hit 50 mph when it warmed up it would act like it shifted down and would not go over 50mph. I changed the crankshaft position sensor and it runs great. I still have the P0700 code come up. I don't know what to do. Please help.
Do you
have the same problem?
Thursday, March 25th, 2010 AT 2:52 PM
  • EXPERT
PO700 - Transmission Control System Malfunction
Your P0700 code needs to be addressed ASAP. This identifies a problem with the solenoid pack, which is an external part that can be fixed for around $200 if you do it yourself, $300 if you take it somewhere. But a bad solenoid pack can damage the tranny resulting in a total rebuild, which runs anywhere from $1500 to $2500 depending on where you have it repaired.
Thursday, March 25th, 2010 AT 8:51 PM
Recommended Guides
