2000 Dodge Dakota
BURNSCLAYTON
  • 2000 DODGE DAKOTA
Heater problem
2000 Dodge Dakota 6 cyl Four Wheel Drive Automatic
how to replace heater core at home on this vehicle?
Do you
have the same problem?
Saturday, November 22nd, 2008 AT 9:00 AM
BMRFIXIT
  • EXPERT
1.Disconnect negative battery cable. Drain cooling system. Remove instrument panel.
2.In engine compartment, disconnect heater hoses and plug all openings. Remove 4 heater assembly nuts from engine compartment firewall. Inside vehicle, remove heater assembly support brace screw, and swing support brace out of way. Move passenger seat rearward.
3.Carefully pull heater assembly rearward until studs and heater core tubes clear firewall. Lower heater assembly. Remove heater assembly from vehicle.
4.Place heater assembly on work bench with assembly housing cover facing down. Remove 2 bolts securing heater assembly housing cover to blower motor housing cover. Unplug vacuum harness connector from panel/defrost door actuator.
5.Remove floor duct from heater assembly housing. Remove 2 bolts securing heater assembly housing cover to lower housing near floor outlet. Turn assembly over. Disengage vacuum harness retainer and vacuum harness. Remove 13 screws securing housing cover.
6.Remove blend-air door lever. Gently pry panel-defrost door lever off. Pull up on heater assembly housing cover far enough to separate cover sealant and remove cover.
7.Ensure blower motor housing cover sealant is in place and in good condition. To complete installation, reverse removal procedure.
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_43.jpg
Sunday, November 23rd, 2008 AT 8:02 AM
Recommended Guides
