1997 Dodge Dakota My pick up shifts into neutral when cold
RICKYD123
  • 1997 DODGE DAKOTA
  • V8
  • 124,000 MILES
When I get in and drive my pick up, it shifts into neutral sometimes. When it's cold and I roll up on a stop sign it will shift into neutral. If I give it some gas, it will go into gear. Once it gets warmed up it stops doing it. The transmission works fine from then on. I think it might be a sensor but I don't know. Can anyone help.
Do you
have the same problem?
Wednesday, September 8th, 2010 AT 4:35 PM
  • EXPERT
Are you sure the trans fluid is full and clean?
Wednesday, September 15th, 2010 AT 7:18 AM
Recommended Guides
