1997 Dodge Dakota Check engine light
BSNARR
  • 1997 DODGE DAKOTA
Engine Performance problem
1997 Dodge Dakota 6 cyl Four Wheel Drive Manual
My check engine light keeps coming on. The code says it is a cylinder # 5 & #6 misfire & random misfire. I changed the plugs, wires, cap & rotor. Made sur the wires were all hooked up right. But the check engine light came on again with the same code? HELP please.
Do you
have the same problem?
Thursday, April 22nd, 2010 AT 9:35 AM
Check compression and injector for those cylinders
Thursday, April 22nd, 2010 AT 6:55 PM
Recommended Guides
