1996 Dodge Dakota Will not start - starter dragging
CARCRASHR
  • 1996 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 138,000 MILES
Truck just will not start! Bought a new battery. (The old one tested good at Autozone). Alternator tested good. Starter tested good. But when all are re-installed in the truck, the starter turns so slowly it will not start. A very low growl of a turning. Like the battery is one key turn from being dead.
Do you
have the same problem?
Thursday, October 2nd, 2008 AT 7:27 AM
  • EXPERT
Hi:
If all the connections are clean and tight, it sounds like the starter is drawing too much power. Was the starter removed and bench tested? If not, I would try it that way (maybe get a different starter to try). I think they may have missed something unless there is reason to believe there is an internal engine or flywheel problem.
Let me know what you find.
Tuesday, October 21st, 2008 AT 9:05 PM
Recommended Guides
