1995 Dodge Dakota Stall and shift
TYRAMINE
  • 1995 DODGE DAKOTA
  • 6 CYL
  • 63,000 MILES
The truck has a delayed shift between first and second and is also stalling idle is around 800-1000 rpm's
Do you
have the same problem?
Thursday, March 20th, 2008 AT 8:51 PM
When was the transmission last serviced?
Could be a problem with the transmission converter clutch/overdrive solenoid or shifting solenoid. Also have the throttle position and vehicle speed sensor checked this 2 sensors inputs signal to the computer as an indication of throttle and governor pressures.
If it continues get the transmission pressure tested to find problems internally-
Thursday, March 20th, 2008 AT 9:54 PM
Recommended Guides
