1995 Dodge Dakota
TXBOWTIE72
  • 1995 DODGE DAKOTA
Engine Mechanical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic
where is the fuel interia switch located on the dodge dakota
Do you
have the same problem?
Sunday, June 27th, 2010 AT 3:30 PM
INTERNETMECHANIC
There is no inertia switch. Have seen it on some fords not dodge or gm.
Can you check for applicable mil codes? The info below tells how to check mil codes. Use a gage and check fuel pressure. Check the circuits at the fuel pump relay.
http://www.2carpros.com/forum/automotive_pictures/512072_dodge_dakota_mil_codes_1.jpg
Sunday, June 27th, 2010 AT 3:58 PM
Recommended Guides
