1993 Dodge Dakota "Spark Plugs Not Firing"
DAKOTOA982
  • 1993 DODGE DAKOTA
I have a 1993 Dodge Dakota that the spark plugs arent firing on. I have changed the coil, cam shaft sensor, ECU and distributor. I checked it and there is no fire getting to the coil from wherever it comes from. The only thing I know of now that could be the problem is the ignition switch. The truck turns over and trys to crank up just fine I just cant get the spark coil to send fire to the spark plugs. If anyone could tell me what could possibly be wrong with it I would greatly appreciate it.
Do you
have the same problem?
Thursday, January 26th, 2006 AT 9:02 PM
JACK42
Crank angle sensor
Friday, January 27th, 2006 AT 5:42 PM
Recommended Guides
