2006 Dodge Charger
JASMINEDRONES
  • 2006 DODGE CHARGER
Transmission problem
2006 Dodge Charger Automatic
I have a dodge charger r/t and the gear shift stick wont move out of park. When I get into the car and start it I press on the brake so I can move it into reverse but it wont let me move it at all. What could be the problem?
Do you
have the same problem?
Saturday, June 6th, 2009 AT 12:05 AM
JACK42
If it is the same one in the 300's the shifter is probably broken. Can you hear the shifter click when you push on the brake pedal? If so theshifter is bad, turning out to be acommon problem for those Dodges, it is all plastic and inexpensive to have repalced. If you pop the top bezel off, you should be able to go in there and get it out of park so you can take it in to be fixed
Saturday, June 6th, 2009 AT 8:02 AM
Recommended Guides
