Fuel filter?
ALICIAS4U
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 180,000 MILES
How do I find and change a fuel filter in a 99 dodge caravan?
Do you
have the same problem?
Tuesday, November 23rd, 2010 AT 4:09 AM
JDL
  • 16,098 POSTS
The fuel filter is on top of gas tank. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Tuesday, November 23rd, 2010 AT 4:23 AM
BMRFIXIT
  • 19,053 POSTS
If you have one its on top of the fuel tank
have to support and drop the tank down about few inches to be able to remove filter
Tuesday, November 23rd, 2010 AT 4:25 AM
CMCJC24
  • 1998 DODGE CARAVAN
1998 Dodge Caravan 54000 miles
how do I change a fuel filter. Can you tell me or send me a diagram on how to do it
Thursday, December 17th, 2020 AT 8:51 AM (Merged)
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_caravanfuelfilter_3.jpg
You need to lower the fuel tank to gain access to the fuel filter.
LIVEWIRE7965
  • 1995 DODGE CARAVAN
Six cylinder two wheel drive automatic 164,325 miles.
Where is the fuel filter located?
Thursday, December 17th, 2020 AT 8:52 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
The fuel pump is on top of gas tank fuel filter is in front of muffler on the passenger side.
Here is a guide to help you see what you are in for when doing the job.
Cheers
LIVEWIRE7965
Is there a panel or something under carpet to get to it or do I need to drop fuel tank?
ROWTIEAR
  • 91 POSTS
The fuel filter is located on the passenger side frame rail approximately halfway up the van there is an exhaust shield right in front of it so it is hard to see. Just follow the fuel lines from the tank and you will find it. It is connected with short pieces of rubber line and hose clamps so it is an easy one to change.
KENNY2
  • 6 CYL
  • 185,000 MILES
Looking for gas fillter im changing plugs and wires and gas filter, if I can find it.
Thursday, December 17th, 2020 AT 9:04 AM (Merged)
Locations
Fuel Tank, Filter, And Chassis Line Routing
https://www.2carpros.com/forum/automotive_pictures/12900_f_7.gif
The in-line fuel filter is found along the right side frame rail between the fuel tank and engine.
CARAVANQUESTIONS
  • 1989 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 180,000 MILES
I was wondering where the fuel filter is, I have the extened wheel base 119" and it is a 3.3 L.
Thursday, December 17th, 2020 AT 9:05 AM (Merged)
DLOBI
  • 125 POSTS
The fuel filter is on the under side of your van about halfway between the gas tank and the engine. It will look like a metal canister a couple of inches long.
LIQOURPIG
  • DODGE CARAVAN
Where the heck is the fuel filter located on a 1997 dodge caravan?
Please& Thankyou
MERLIN2021
  • 17,250 POSTS
It's up on the engine were the pressure regulators, high and low are...Relieve pressure before replacing!
https://www.2carpros.com/forum/automotive_pictures/62217_Fuel_Filter_1.jpg
