2006 Dodge Caravan fuse
DOUG METCALFE
  • 2006 DODGE CARAVAN
  • 6 CYL
  • 40,000 MILES
My right rear turn signal doesn't work but the front does. First, is the problem a bulb or a fuse? Second. If a fuse there is no clear indicator on the fuse box cover as to which fuse to change. Please advise.
Thanks,
Doug Metcalfe
Do you
have the same problem?
Saturday, May 8th, 2010 AT 8:31 AM
BMRFIXIT
  • EXPERT
NOT a fuse
check the bulb and replace 1st
Wednesday, May 12th, 2010 AT 6:33 AM
Recommended Guides
