2005 Dodge Caravan
HARRYWHITE61
  • 2005 DODGE CARAVAN
2005 Dodge Caravan
where is the coolant control module for fan located
Do you
have the same problem?
Wednesday, December 30th, 2009 AT 5:02 PM
CH112063
A temperature sensor is used as information shared by a few computers. This sensor is called a ECT sensor. What's wrong, overheating? It should store a powertrain control module code. The PCM is the coolant control, grounding the fan relays. Today there are 60 different names for one sensor. Rarely does this sensor fail. Let me know if you need help. OK?
Wednesday, December 30th, 2009 AT 8:17 PM
Recommended Guides
