2004 Dodge Caravan
TECH39MUR@YAHOO.COM
  • 2004 DODGE CARAVAN
Heater problem
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic
no heat at idle has new thermostat and no leaks, full coolant
Do you
have the same problem?
Sunday, February 7th, 2010 AT 2:22 PM
BMRFIXIT
  • EXPERT
Do you have rear heater?
Does the engine reach operating temp
If so check both heater hoses at by the fire wall they should both hot are they
If so have to run self check looking for codes, as you may have a defective blend door and or actuator
If one heater hose hot and one cold or warm have to check for clogged in the system and suspect heater core need to be flushed
Sunday, February 7th, 2010 AT 3:01 PM
Recommended Guides
