2003 Dodge Caravan Engine Stalling and Speedometer stopped
JSSWOFFORD
  • 2003 DODGE CARAVAN
Engine Performance problem
2003 Dodge Caravan 6 cyl Automatic 109000 miles
My engine has just started stalling while driving this week. Once I was parked at a stoplight, once I was accelerating from being parked in a parking lot and once I was going 35 miles and hour. Yesterday we couldn't get it started for a couple of hours, today both times it stalled I was able to start it right away. However my speedometer went out today too. Are they possibly related? Thanks for any help.
Do you
have the same problem?
Wednesday, May 12th, 2010 AT 12:43 AM
BMRFIXIT
  • EXPERT
With engine running do you have check engine light on?
1st step should be to check for codes
most part stores can help you in getting the codes for free check in your area
with engine off try to cycle ignition key ON OFF three times ending with key on read in odometer area codes
suspect crank sensor, vacuum leaks, wiring harness
codes should indicate to trouble area
let us know what you have for codes
Wednesday, May 12th, 2010 AT 6:22 AM
Recommended Guides
