2002 Dodge Caravan engine shuts down
DFA
  • 2002 DODGE CARAVAN
Electrical problem
2002 Dodge Caravan Front Wheel Drive Automatic 42000 miles
when running at 50 to 60 mph it momentarily shuts off and on in a matter of half a second when this happens the cruise control light in the dashboard comes on and off to, when I have to make a stop the engine shuts off but I put the transmission on neutral and hit the switch and starts on again this is much the problem. Need some help
Do you
have the same problem?
Tuesday, January 27th, 2009 AT 5:14 PM
  • EXPERT
Hi:
Has the check engine light come on? You may want to take the van to a nationally recognized parts store and have them scan the computer for codes. Most will do it for free.
If nothing is found, have the fuel pressure tested. Again, you can rent or borrow the gauge from many parts stores and all you need to do is hook it to the fuel rail to test the pressure.
Let me know what you decide.
Thursday, January 29th, 2009 AT 1:34 PM
Recommended Guides
