2002 Dodge Caravan Door
MIMIVAN
  • 2002 DODGE CARAVAN
Electrical problem
2002 Dodge Caravan Two Wheel Drive Automatic 152925 miles
The sliding door on the passenger side does not unlock and therefore doesn't open.
Do you
have the same problem?
Sunday, November 15th, 2009 AT 1:54 PM
CH112063
The sliding door trim panel can be removed and a pin may have been dislodged. It seems impossible but it is held in mostly by clips that pry out with the panel. With door closed. A handle cover and couple of screws also. It comes off, take off plastic, and use a flashlight to check for a missing long pin, that may have come unhooked from the latch system. Common problem. Ok
There is room, just tight.
Monday, November 16th, 2009 AT 1:20 AM
Recommended Guides
