2002 Dodge Caravan check engine light on
KEEF216@COMCAST.NET
  • 2002 DODGE CARAVAN
  • 6 CYL
  • 4WD
  • 63,000 MILES
I have a dodge grand caavan sport who's check engine light is on we did a diagnostic test and it comes up with the code PO442 and PO455 which we know it has to do with evap emissions what is the easiest way to solv this problem if there is a simple solution?
Do you
have the same problem?
Tuesday, August 18th, 2009 AT 10:09 AM
WINEBURGER
Evap emmision codes are usually for loose gas cap
Tuesday, August 18th, 2009 AT 10:13 AM
Recommended Guides
