2002 Dodge Caravan Can't start or engage shift lever
Electrical problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic 59,500 miles
This is strange. Inserted my key fully but it would not turn. Thus dash lights did not illuminate as normal, nor could not get out of Park. Steering wheel was movable. Jiggled the level in all directions, but did not want to break it. Got out, attempted to push the car but as in park it only rocked this does work on my tractor, though). Back in, re-insert key, try the duplicate key, nothing. Wife gets in, jiggles the handle again, and suddenly dash lights on as she turns key, and she can shift to drive. ! Drove into town and back, no problem. 2 hrs later, go outside to start the car, and same thing, only I can't get it to go this time? I suspect some electrical relay or module shorted out that controls the ignition/shift mechanism, but I am hardly qualified to judge. Your ideas?
Do you
have the same problem?
Friday, November 21st, 2008 AT 6:03 PM
  • 2,294 POSTS
Dodge minivans seem to have this problem a lot.
try answer 2-A
There are 4 things that I see over and over again, that keep an ignition lock cylinder from turning.
The steering wheel lock is under pressure.
When you turn off your car and remove your key.
A spring loaded post sticks up in to one of many holes in the steering wheel.
This locks the steering wheel in place, making your car harder to steal, because a bad guy cant turn the steering wheel if they somehow get your car started without the key.
But this can also keep you from turning the ignition lock.
If the steering wheel is under pressure because your front wheels are against a curb, or you have the wheel cranked all the way to one side or the other. The pressure from the steering wheel on the spring loaded post keeps you from being able to turn the key.
So while trying to pull the steering wheel one direction or the other, try to turn the key, this may solve your problem.
The pins are not falling into place.
You kinda need to know how a lock works for this part.
Look at a key and you will see there are different depth cuts in it.
Those different cuts correspond with different length pins in the lock cylinder.
See how the red pins are of different length?
But with the key inserted, they are all even with the blue pins.
When the red pins are held in the correct position by the correct key, the spring loaded blue pins are flush with the outer housing of the lock, and the red pins are flush with the inner cylinder of the lock
And thus the inner cylinder can be rotated.
If debris such as pocket lint, ear wax, or just plain old dirt gets into the pins and causes enough friction for the spring loaded blue pins to not be able to push the red pins back in place.
Then the red pins will be partially stuck in the hole for the blue pins and the cylinder can not turn.
Putting the key in the lock and then tapping on it with a small hammer may help until you have the chance to have the lock cleaned.
Do a search for the word "bump key" if you want to know more about how a lock cylinder works.
The same goes for if a key is worn out.
If a key is badly worn, then it will not put the red pins in the correct spot and some of the pins will keep the cylinder from turning.
If your key is worn out, try a spare if you have one.
Or put the key in and "Jiggle" it while trying to turn the lock.
A problem with the interlock cable from the gear selector to the lock cylinder. Make sure you are completely in park.
You pretty much have to take things apart and visually inspect it to verify this problem.
A mechanical problem with the linkage from the lock cylinder to the electrical part of the ignition switch.
Sunday, December 14th, 2008 AT 5:26 PM
Recommended Guides
