2001 Dodge Caravan air conditioning and loss of power
GAURDMOM1
  • 2001 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 89,500 MILES
As a single mom its hard to find an answer when I turn my air conditioning on my van loses power and doesnt seem to run well it also has like a miss to it. When I turn the air conditoning off it runs normal again
Do you
have the same problem?
Sunday, June 8th, 2008 AT 3:55 PM
OBXAUTOMEDIC
  • EXPERT
OK, Does the A/C work normally? Is the Check Engine Light On?
If A/C Doesn't work normally then it may need to be replaced. Sounds like it may have bad or going bad compressor.
Sunday, June 8th, 2008 AT 9:30 PM
PYHAINES
I have the exact same problem. Did you find the solution?
If A/C Doesn't work normally then it may need to be replaced. Sounds like it may have bad or going bad compressor.[/Quote:07c5a73c5d]
Tuesday, July 22nd, 2008 AT 1:53 PM
Recommended Guides
