1999 Dodge Caravan
RBARRETO
  • 1999 DODGE CARAVAN
Electrical problem
1999 Dodge Caravan 4 cyl Two Wheel Drive Automatic
AFTER TAKING THE ENGINE OUT TO REPLACE ALL SEALS AND HAVE THE HEAD REDONE PUT THE ENGINE BACK TOGETHER PAYING ATTENTION TO PROPER TIMING, THE CAR WILL NOT START NOW, TURNS BUT WON'T START. CHECKED FOR SPARK AND HAVE IT. CODES P0351 and P0352 CODES SHOWED BY THE CHECK ENGINE LIGHT.
CAN LEAVING IGNITION KEY ON THE "On" POSITION FOR A COUPLE OF DAYS HAVE DAMAGED THE PCM OR THE IGNITION COIL?
Do you
have the same problem?
Saturday, May 1st, 2010 AT 12:42 PM
  • EXPERT
Both codes are for problems with the coils. Are you getting a good hot blue snapping spark? Are you sure the wires going to the coil are tight and clean? Also, will it start with starting fluid? Finally, have you checked fuel pressure?
PS:
P0351
Ignition Coil A Primary/Secondary Circuit Malfunction
P0352
Ignition Coil B Primary/Secondary Circuit Malfunction
Sunday, May 2nd, 2010 AT 12:15 AM
Recommended Guides
