Front hub bearing replacement instructions please?
ANONYMOUS
  • 2009 DODGE CARAVAN
The front hub bearing was replaced a couple of months ago and now I am having the same problem again. My question is, can I still drive my van for at least for a month without replacing the said bearing? I need to do the job again please help.
Monday, December 17th, 2012 AT 2:24 PM
The wheel bearing is only going to get worse. So I would not let it go for long. We can't tell you that you will be fine or not as it may fail tomorrow or a year from now.
Here is the info that will help with this including a video that will help with this:
https://youtu.be/ZgiPRG6jffc
Below is the process from the manual.
Let us know if you have questions. Thanks
Thursday, February 25th, 2021 AT 7:24 PM
SSTRINKO
  • 2007 DODGE CARAVAN
  • 3.3L
  • 6 CYL
  • 129,000 MILES
I have a 2007 Dodge Caravan. I recently had the front brake pads replaced and everything seemed ok. It has been a couple of months and I am starting to get this horrible grinding sound in the front wheels when I decelerate from higher speeds. The sound is exasperated the higher the speed and the harder I apply the brakes. I am also noticing an abundance of blackish residue that builds quickly after cleaning. Please advise.
Saturday, February 27th, 2021 AT 1:40 PM (Merged)
HMAC300
  • 48,601 POSTS
This could be a couple of things not necessarily brakes. Have wheel bearings check first. Rust buildup and falling off will also cause this. Frozen calipers and cheaper brake pads wear faster. Ceramic pads are the best but more expensive. Also the way people drive wear them faster. Look at brake pedal if left side of pedal is worn down you stop with your lieft foot and consequently your foot rides on brake pedal and the brakes are applied as it only takes 4 lbs of pressure to do this. So have your brakes checked to see what is exactly is. Also if you are seeing black grease it may be a boot torn on the axle and throwing grease out of joint so it will probably have to be replaced.
SSTRINKO
Great. Thanks. I think it may very well be the bearings. The black is more like a residue than a grease. Very hard to remove. How do I know if it is the bearings and if it is, is it potentially a do it yourself project for a mechanically inclined individual? Also I drive with right foot only.
HMAC300
  • 48,601 POSTS
Find an empty parking lot, drive in a circle one way and listen for noise then drive other way in circle listen for same thing if it's a bearing it will make a grinding or whining noise. Most mechaniclally inclined people can do this. See pics
HERZ
  • 2002 DODGE CARAVAN
  • 90,000 MILES
My name is Herz. Could someone please, Tell me what kind of rear Wheel Hub Assembly (( Dodge Caravan 2WD Wheel Bearing & Hub Assembly Rear )), Do I purchase for my Dodge Caravan 2002 engine 3. 6cyl, when I try to do a purchase, there are so many that I truly do not know, what should I buy for my Van, Also the screws to attach the peace together, someone said I needed nugs and bolt but I dont know what king or sizes, my tire size is 215_715 in case this helps.
Thank you
HMAC300
  • 48,601 POSTS
Your wheel bearing will go where i've pointed out it may take what is called a torx bit to remove bolts. They will need to know if this is all wheel drive and if it has abs. Maybe a few other tings. All wheel drive bearings will be different so when yo go to parts store tell them what you have.
HERZ
Hi
When I go to a store to purchase wheel bearing. They try to sell me the hight price to make extra money, I found on line its half price, But I do not know which one to purchase or screw and bolt sizes or if its abs, then they ask me all those questions about my van, I dont know if its front wheel or back wheel drive, n/a what size are those bolt and screws. Please reply.
HMAC300
  • 48,601 POSTS
Besides the wheel bearings they sell you at different prices are not to make extra money. If you see it online it is probably Chinese manufactured which is a low quality part and will fail quickly. I not they cannot fix or get the right part for your vehicle if you don't know what you have. Nor do I know what size bolt/screws are, when I work on a vehicle I have my tools right there and because there are so many different applications unless I work specifically on your model I have no idea what you have. Thanks you for using 2carpros.
SEANLEWCHUK
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 170,000 MILES
I am having trouble removeing the old rear wheel hub assembly I got the 4 bolts off but it still wont budge can you please help me?
LEGITIMATE007
  • 5,121 POSTS
I think you'll need a rubber mallet and you'll have to keep hitting it until it budges, but first look on the inside just to make sure there isnt anything keeping it hung up
CEELO
  • 1994 DODGE CARAVAN
  • 6 CYL
  • AWD
  • 120 MILES
Had my '94 Dodge Caravan SE 3.3L V6 right-rear wheel cylinder reviewed & after leaving mechanic shop (10-15 mins) later my entire HUB was dismantled while driving. Towed car to shop for repair. Curious to know whether the individual made a costly mistake when re-mounting my wheel or is it known that a bad cylinder could lead to a bad HUB? No prior noise or vibration until the DRUM was removed to view leakage from the cylinder. Please advise. Thank you for your assistance.
LEGITIMATE007
  • 5,121 POSTS
No, a bad brake cylinder cannot lead to a bad drum, what I am pretty sure happened is, when they removed the drum they need to remove the bearing cap and bearings etc. When you put it back you need to repack the bearings with grease, without that grease, everything will heat up and decentagrate ( know I didnt spell that right) and literally take the whole tire off, I know because, before I went to school for this, I did it to my own 93 grand caravan. Bad situation
DOCFIXIT
  • 18,828 POSTS
See Diagram is this the hub you question? If yes I know of noway a wheel cylinder replacement would cause hub to fail. Unless it was removed to make acess to cylinder easier. Did nut come off?
DOCFIXIT
  • 18,828 POSTS
Diagram
LEGITIMATE007
  • 5,121 POSTS
Im sorry I meant hub not drum
LEGITIMATE007
  • 5,121 POSTS
On these caravans the studs are in the drum and in order to remove the drum have to remove the dust cap, pin, cotter pin and bearings, it doesnt have a hub assembly
CARADIODOC
  • 33,729 POSTS
To add to the story, (hi guys), the drum is not meant to come off the hub. The two pieces are held together with the studs. The assembly is removed after removing the spindle nut and outer bearing. My guess is they pried the drum off, then didn't get it centered on the studs so the wheel worked loose while driving. The driver should have noticed the wobbling feeling and possibly heard the noise, but if not, the drum would now fall off if the wheel came off. Probably wrecked the backing plate.
Caradiodoc
